7 segment with d-flip flops!
hi guys again!! remember me?
  i have another easy question for you that troubles me!
i am trying to see how this circuit works! since i am a beginner i made all the steps i found in the fundamental of digital electronics here! i made the truth table then the karnaugh tables and ended up in the equations of each exit! i made my own circuit with and,not and or gates! and it worked perfectly!! in this circuit down there i get lost!! in this vi they use compound arithmetics and some and and nand gates and also d-latches!! i know how a d-flip flop works but here all these combined confuses me!
can someone please guide me through the vi ?what all these buttons do?
thanks for your time!
you are not obligaded to help!! thanks again!! Smiley Happy
Message 1 of 23
(6,147 Views)
can you post you vi so we may helps you futher?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 23
(6,130 Views)
here it is!! i know my questions might sound silly to you guys but i am too new at all these and you are my only chance of debade and discussion!!
Message 3 of 23
(6,116 Views)
I hope this helps it is an example of two 7 segment LEDs
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 4 of 23
(6,101 Views)
i can't open the vi's cause my labview is an older version! 😞
Message 5 of 23
(6,096 Views)
I am sorry what version are you working with?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 6 of 23
(6,091 Views)
i use 8.5
Message 7 of 23
(6,086 Views)
here it is in 8.5
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 8 of 23
(6,084 Views)
pls attach the subvi related to ur program.... its showing error without the subvi....
N. Srinivasan
Message 9 of 23
(6,064 Views)
here is the sub vi and if that helps i found what the buttons do! q1-q4->outputs  a1-a4 inputs, clk->clock, co-> carry out
te,pe->counter and program enable and cl-->clear also load --> it loads  p1-p4 value to the exits a1-a4!!!  i need someone to help me understand what is happening in the block diagram!! some kind of circuit analysis! thanks so much again
Message 10 of 23
(6,059 Views)
