8.5 programming palette
When i installed the 8.5 demo it changed the way the palette is displayed when I right click on a block diagram in my versio 8.0 install. Is there a way to get back the old palette? It takes too long to navigate to the programming area.
(2,960 Views)
Right click on the block diagram and then Pin the pallete to the block diagram (using the thumb pin).  Then select "View" and "Change Visible Categories".  Now select the top one "Programming" and deselect the one you dont want, I believe it is called "Express".  You can play with this part until you get it to suite your needs.
Cheers!
(2,959 Views)
