Why am I occasionally getting a "no listeners" error with my GPIB communications
I have an application that is using a GPIB-ENET/100 controller to command a power meter and a spectrum analyzer. Using NI Spy I am getting timeout errors which are not really hurting anything. What does hurt my testing is when I get a "no listeners" error which pretty much halts my application. One other thing to add is that I cannot duplicate this on my development machine. It is only on the machines that are running the application which this happens. I don't get the timeout errors either on my development machine. Is there something unique to applications vs the development VIs that I should be aware of? All machines are running XP. I am using the Instrument Assistant to write to and query my spectrum analyzer. So when debugging this in the application I cannot open the Instrument Assistant VIs to run commands individually and like I said I cannot duplicate the problem on my development system so that does not help. Any help would be appreciated.
Troy
(3,088 Views)
Is the application machine has some debug program like MAX.  Does the development machine has a GPIB board and actually connects to the instrument?  Is the GPIB board in the application machine works properly?
------- LabVIEW 2009, So Easy, Even a Therapist Can Do It -------
(3,081 Views)
The application machine does have MAX on it. That is how I am using NI Spy. I am using the same GPIB-ENET/100 for both the application and the development machine. Only one machine is ever accessing the controller at any given time.
(3,078 Views)
Is that could be something's wrong with the GPIB-ENET/100 controller on the application machine?  Hardware problem?
(3,066 Views)
You will need to make sure you have NI-488.2 installed and this should install MAX. You will first have to setup the ENET 100 in MAX before you can run your program.
Regards
Krista S.
Applications Engineering
(3,040 Views)
