RTX for Labview 8.5
Is the RTX version of real-time being phased out?  I was thinking of using it instead of ETS but it looks like it is not supported past version 8.2.
thanks,
rob
(2,927 Views)
Hi Rob,
We still support RTX for 8.2 and previous versions, but if you would like to use LabVIEW 8.2.1 or newer, RTX will not be supported. I would recommend using ETS unless you have specific limitations that prevent you from doing so. This KnowledgeBase article describes a little more about the differences between RTS and ETS.
Hope this helps!
Amanda Howard
Americas Services and Support Recruiting Manager
(2,909 Views)
