8 bit buffered output
I would like to implement an 8 bit buffered output VI using a HS32 card and
LabVIEW. The examples provided with LV only allow 16 bit buffered output
(Digital DblBuffered Pattern Generation.vi).
(3,403 Views)
I don't think it is possible to have digital buffered output. Buffered
output is only used in analog output
Mark Villela wrote in message
news:387bba0a@newsgroups.ni.com...
and
> Thanks
(3,403 Views)
Sorry, I was wrong. It IS possible to have digital "buffered" output. You
can use the 6533/PCI-DIO-32HS
"Koen Hooogstoel" wrote:
>I don't think it is possible to have digital buffered output. Buffered>output
is only used in analog output>>>Mark Villela
wrote in message>news:387bba0a@newsgroups.ni.com...>>>> I would like to implement
an 8 bit buffered output VI using a HS32 card>and>> LabVIEW. The examples
provided with LV only allow 16 bit buffered output>> (Digital DblBuffered
Pattern Generation.vi).>> Thanks>>
(3,403 Views)
