How can I convert string to integer?
I had get date string: "1/14/2000" ,
Now I want to get the integer numbers: Year=2000, Month=1 and Day=14
Help me!
---A newbie
Sent via Deja.com http://www.deja.com/
Before you buy.
(4,545 Views)
Use 'Scan From String' function from the 'STRING' functions menu:
[Image]
-Franz
> Help me!
> ---A newbie
> Before you buy.
(4,545 Views)
>Help me!
have a look at the string function "Scan From String".
Set the format string to "%d/%d%d"
Make the function to have three outputs terminals.
I would also advise to connect a dummy integer to the three default
terminals.
To get some error checking on the conversion check the error out
terminal.
Rolf
(4,545 Views)
Hello mister newbie :),
Here's a VI what will do the job. Scan from string is very powerfull for
this kind of jobs.
Happy wirering,
Roger
hotoo@my-deja.com heeft geschreven in bericht
<85mvj3$kr1$1@nnrp1.deja.com>...
>Help me!
>---A newbie
>Before you buy.
[Attachment $_string to int_date.vi, see below]
(4,545 Views)
