8196 RT Controller : Connected - Safemode Improper Installation
I am using 8196 RT controller with LabVIEW 8.5.1 and DAQmx Version 8.7.1.The RT controller is frequently getting disconnected from NI MAX, but it gives reply when we try the ping command. When I tried to deploy RT exe I am getting the following errors at different time.
Error message : internal errror : "memorymanager.cpp", line 406 LV version 8..5.1
rebooting system due to exception 0x80000003
rebooting system due to exception 0xC0000005
Thmutex.cpp line 209
In NI forum experts advisided to reformat the controller and Install the desired software. I reformated the controller and Installed the softwares and now I am getting the error in NI MAX - System State : Connected - Safe Mode (Improper Installation).
Any help or advice will appreciated, thanks in advance.
Please find the attachment and weblinks for reference:
http://digital.ni.com/public.nsf/allkb/B2BA1B006C12B1A2862575D60044E192
http://208.74.204.114/t5/PXI/System-Error-in-PXI-8106-exception-0x80000003/m-p/825997
http://forums.ni.com/t5/Real-Time-Measurement-and/0xC0000005-exception/m-p/711543?requireLogin=False
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 1 of 1
(2,655 Views)
