Help with data logging
I have made a program with sensors using CRio. There are four different sensors and they work well when being run. The next step i have to do is to log the data for every few seconds but i don't know how. I am very new to Labview. Can anyeone help?
(2,540 Views)
Oh my Infinite Loops!   Oh my redundant code!
You should start here:  https://learn.ni.com/learn/article/labview-tutorial
Lots of options for writing to disk every few seconds.  But you could buffer the values into an array, pass the array between iterations using a shift register, and then put the "write to disk" code in a case structure which you call from a case structure after X seconds have elapsed.
Also have a look at the "LabVIEW Example Finder" (help > find examples) ... you might find some good examples for writing to disk.
http://www.medicollector.com
(2,491 Views)
