8451 SPI Error with ADXL346
All,
I have an error when trying to use the Analog Devices ADXL346 with the NI USB-8451 over SPI.  I recieve the following error:
"Error -301713 occurred at Property Node (arg 1) in SPI_Simple_forum.vi
Possible reason(s):
NI-845x:  An input parameter, or combination of parameters, is invalid. An example of this error may be setting an invalid baud rate or enabling I2C ACK polling while using 10-bit addressing."
The interesting thing about this is it only occurs when the I/O voltage is anything but 3.3V.  When it is 3.3V I do not get the error.  However, the I/O voltage of the device is set at 2.5V so I believe I need to set the 8451 I/O voltage to 2.5V and thus get the mentioned error.  Because the error only appears when I change the voltage, I can conclude it doesn't like the voltage selection but I don't know why.  Any insight?  Thanks.
My VI, and datasheet are attached.
(3,653 Views)
Accepted by topic author lgbav8r
Hey,
Sorry, but I'm pretty sure you're getting the error because the USB-8451 is not capable of variable voltage levels.  If you look at the NI-845x Hardware and Software Manual, in Appendix A, it does not mention anything about being able to change the voltage levels on the USB-8451.  If you scroll down a little to the USB-8452 section, it does.  If you have any more questions about this, please feel free to ask!
Best,
Jeff S.
(3,634 Views)
Thanks Jeff.  I see that.  I basically copied the NI example for reading and trimmed it down for this chip.  I guess the example is more geared to the 8452.  So does this mean the 8451 cannot work with this accel since the supply voltage is 2.5V and a supply voltage of 3.3V would exceed the maximum for this device?
(3,631 Views)
I didn't look at the spec sheet for the ADXL346, but I wouldn't use an out of spec voltage with it.
Jeff S.
(3,609 Views)
I have acquired an 8452 and with that set to 2.5V the ADXL346 works perfectly
(3,536 Views)
