Stepper motor and sequence
There are stepper motor vi and sequence vi at the attach file. I want to control stepper motor via sequence vi. When I run the stepper motor vi, it can not be reached part of enter position. How can I integrate sequence vi into the stepper motor vi.
Message 1 of 10
(3,979 Views)
Sequence vi ?
Message 2 of 10
(3,942 Views)
Sequence vi.
Message 3 of 10
(3,922 Views)
You can put the code together in the same VI. You can use two different while loops running in parallel. I don’t see a problem. If you want to transfer data between loops you can use a queue (something like Producer-consumer architecture).
Message 4 of 10
(3,894 Views)
Actually, not exactly what I mean. I want to control MG17 Motor in the stepper motor block diagram by the "sequence". However, I can not add it to Stepper Motor vi.
Message 5 of 10
(3,892 Views)
Do you mean that you need comunication between them without putting them together?
Message 6 of 10
(3,890 Views)
Yes, I want to control "enter position" in the MG17 Motor.
Message 7 of 10
(3,888 Views)
For communication between VI you can use global variables (taking care on race conditions), shared variables, web services, W/R to files (I think do not apply in this case)…
Message 8 of 10
(3,882 Views)
I tried it but it does not work.I think, I need to new vi with regard to stepper motor that I can change and control it. Thank you very much for your help.
Message 9 of 10
(3,876 Views)
Well, that can be a solution too. But you can try to implement this communication between VIs with a simple code just to prove it, and then you can add the other functions.
Message 10 of 10
(3,853 Views)
