9474 motor control
Hi together,
i´m new here in LABview forum.
I got the following problem.
I got a EC-motor, which were controlled by PWM- signal.
base:
The interface of the motor has a "high"- Signal the whole time on it´s control- input, which is ok, because i want to interrupt it (PWM from 0-100%) with my NI card.
I can generate the PWM- signal by NI cDAQ-9174 with NI9474 digital module from 0-100% if it´s not connected with the control-input of the interface, but í´m worry when i connect it, because then i got the whole time a "High- signal" and can´t steer this motor
I already checked my wirements, but they are ok (same GND a.s.o)
Thanks and the best regards
Jo
(2,495 Views)
hi Jo,
How do you manage to determine that your duty cycle is correct when the motor control is not connected but incorrect when the control is wired?
Best regards
______________
Florian Abry
Inside Sales Engineer, NI Germany
(2,449 Views)
