error 1003 advanced tab installer
Recently, whenever I have gone to edit the properties for a installation builder, I get Error 1003.  Specifically when I click either shortcuts or advanced in the items menu on the left.
I followed the path to the vi that has an error, and it can not find CDK_BrowseforTargetFile.vi
Anyone have this problem previously?  I am really hoping I won't need to start uninstalling/reinstalling...
(2,404 Views)
You should try to do the following:
1. (Re)Boot the PC. Start LV.
2. Create a new, blank project.
3. Create a new build script.
4. Go to the stated tabs and see if error occurs.
If it does, you should try a repair install for LV.
If it does not, the error is created by this special project. I would focus my search on dependencies of the top-level VI first.
Norbert
Norbert
Expert: Geometry
(2,390 Views)
