9871 FPGA serial download cause error -65536
Hello
I am working with a CRIO-9047 with multiple SCAN modules and a 9871 for serial communication. I run in hybrid mode, interactive mode (for the FPGA) and use the “NI-987x Serial Loopback.lvproj” for the FPGA implementation.
Now, periodically (~50ms) I use the serial communication to enquire about the status of external hardware, this works flawlessly with a fast response of about 10 bytes. Also if I disable my real-time loop (containing scan-engine) the problem is non existent, so by itself there is nothing wrong with the serial.
However, the problem ensues when I try to download a package of data, in this case 4006 bytes. Executing the download will cause the SCAN engine to crash with the error code -65536, or at least this is what I think happens. (Debugging has been exceedingly difficult for some reason) If I run some of the code in "Highlight executing" mode I can avoid crashes, but I believe this is incidental. I've tried inserting wait functions where I've thought I had "greedy loops". I can not seem to get a grasp of what the problem actually is.
My intuition is that I have a memory integrity error or I am overloading a CPU with a greedy loop.
I would very much like someone else's opinion on this matter.
Kr Jonas
(1,924 Views)
I have attempted to set up a synchronization between the FPGA and the Scan engines scan cycles (Attached) however this does not seem to do anything. I am really at my wits end here, having tried everything else I could think of.
It is very clear to me that the FPGA crashes the Scan engine, as I get the errors -65536 and/or -65589, that seem to indicate the scan engine is not deployed (ie. it crashed). Surely I am not the only one who have attempted to run a 9871 serial communication with large data packages while running in hybrid mode?
Kr Jonas
(1,855 Views)
Accepted by topic author jjacob95
The issue was related to synchronisation of the Scan engine and the FPGA, which caused the FPGA to run terribly slow.
(1,795 Views)
