A/D convertor in LabVIEW using a DAQ?
I am a student who is a beginner in LabVIEW.. I was wondering about making a A/D convertor in LabVIEW using a DAQ? Any helps in leading me to the right direction?
Message 1 of 13
(5,128 Views)
The DAQ is an A/D converter.  What are you trying to measure?  What DAQ do you have?
Message 2 of 13
(5,107 Views)
I want to use LabVIEW to generate a sinusoidal signal which can have changing frequency and amplitude and then be abel to throw the signal into a A/D converter to display the digital form as a graph. I was wondering if anybody can help lead me to the right direction?
Message 3 of 13
(5,086 Views)
In your original post, you've said that you've taken some tutorials and could not understand them. Without knowing what you took and the exact nature of your problems, it's hard to recommend something when it might be something you've already tried. I would hope that you've looked at Help> Find Examples or tried the DAQ Assistant. What you are attempting is very basic. Have you at least installed DAQmx and tested the device and your wiring in Measurement and Automation Explorer (MAX)?
Message 4 of 13
(5,079 Views)
I've done of the tutorials by NI, and well to be honest they weren't very useful.
Is there a way to convert my analog data into digital data and then display the digital data on the graph?
Message 5 of 13
(5,068 Views)
To be honest, you seem to misunderstand quite a bit. Please be specific about the actual tutorial you took. There are numerous ones.
Did you do anything at all that I asked about (i.e. test it in MAX)? With a simple DAQ Assistant, the hardware wil convert the signal and the DAQmx driver will return an array of values to your program. One function wired to a graph and you are done.
Message 6 of 13
(5,061 Views)
Yes I have tested it in MAX
Basically this is what I have..
I simulated a signal and put that into analog output.. This output goes into an analog input(I made a closed loop with my NI USB6353). This input gets converted into a digital waveform. I want to have this digital waveform graphed out into my block diagram. Here's my VI
Message 7 of 13
(5,058 Views)
Can you attach an image? I'm using my phone right now.
Message 8 of 13
(5,049 Views)
Here you go
Message 9 of 13
(5,047 Views)
You've already got a graph with a DAQ Assistant to do the read. Everything with the digital stuff and the other DAQ Assistant is just silly.
Message 10 of 13
(5,042 Views)
