A/D convertor in LabVIEW using a DAQ?
The graph is for the analog input(I made a closed loop with my analog output and analoig input).. Basically just graphing the analog voltage. I want to try and convert this into digital waveform and represent it as a graph?
Message 11 of 13
(589 Views)
All you need for that is the simulated signal. Convert that directly to digital (picking number of bits) and wiring that to a digital waveform indicator.
Message 12 of 13
(582 Views)
Where do I find that? Is it in the analog to digital VI?
Message 13 of 13
(577 Views)
