A HSUPA channel Activation vi is not running has anyone encountered the same problem?
I'm trying to activate the HSUPA channels to on via the relevant vi but the vi does not seem to work.
In the HSDPA channel activation the enable of the on state is a bolean option but in the HSUPA activation it is not.
Shouldn't it be the same?
The vi is: RSCMU_WCDMA_NSig_SourHsupaSignEnab or RSCMU_WCDMA_Sig_SourHsupaSignEnab
hope someone can help me.
Nir.
(2,749 Views)
Could you please give a little more information regarding your application?
Also, where precisely are you finding these commands?  Is there reference material attached?
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
(2,719 Views)
I'm trying to create an application that configures the CMU 200 for HSUPA testing with Labview. in order to do that i need to enable the HSUPA channels (HSUPA channels on). I found a vi (from the NI website) that does that but instead of a Boolean control (true/false) that activates the HSUPA to on the vi has the option only for a read option. how can vi change the vi to serve my purpose? P.S Can't seem to add an attachment
(2,710 Views)
If clicking the "Add Attachments" link below the "Submit Post" button doesn't work, could you please post the link to the example  you are using? This will help me see what you are trying to achieve.
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
choose-mc.com
(2,699 Views)
