A VI called by reference with a express VI included does not work!?
HI Michael,
See attached zip new bld file "appl2.bld".
After un-checking the "disconnect" and doing a save as from the builder, the app runs fine.
I have added some indicators that show that the Express VI was loading a unique instance of a hidden VI (?system?).
Un-checking the box did the trick.
This does sound like the issue Michael A. had reported.
Ben
Message 21 of 26
(995 Views)
Note:
I had some difficulty in getting the check box value to save. That is why I did the ave as.
That may be a new bug.
Ben
Message 22 of 26
(993 Views)
DIsregard my comment about the saving. It seems OK now that I am paying attention.
Ben
Message 23 of 26
(983 Views)
Thanks Ben,
Now I know!!!
Best Regards,
Michael
Message 24 of 26
(977 Views)
So do you agree that this is not a new BUG but appears to be a new variation on the "disconnect typedef..." issue.
If so my work is done here and I will NOT be reporting this issue.
Thanks for the adventure. I learned;
1) LV exe's can can non-exe VI provided they are compiled in the same version,
2) I should learn some more about these Express VI things!
Ben
Message 25 of 26
(973 Views)
You're right!!!
Message 26 of 26
(944 Views)
