A breakpoint problem (step into and step over makes differences)
Hi All, I have a subvi to implement read data and return it to display on front panel. Right now it is not working well on display. But when I set the breakpoint to debug, I found the step into the sub vi can make everything work, but if step over this block, it will be the same as the normal operation. Could anyone advise why this differences happend? Thank you very much!
Message 1 of 21
(4,286 Views)
I can't give you an explanation, without seeing the whole picture "in context". try posting your vi and we can have a better look at it as a "whole"...Smiley Indifferent
Message 2 of 21
(4,278 Views)
Message 3 of 21
(4,274 Views)
@bhl3302 wrote:
When run at normal speed the sub-Vi may be returning an error. Since you are not using a SR for the error, subsequent iterations may be stepping on the error code.
If that guess does not exaplin it, show us the sub-VI.
Ben
Message 4 of 21
(4,271 Views)
Hi Ben, are you talking about adding a SR like this? It still cannot work if this is what you are saying. If not, could you advise how to do?
Message 5 of 21
(4,268 Views)
That is the shift register Ben was referring to.  But the question was whether or not an error was being generated.  The shift register is needed in order to preserve the error.
If there is no error, post the actual subVI.
GCentral
Message 6 of 21
(4,266 Views)
@crossrulz wrote:
... Ben was referring to....
Kudoes to you cross for doing a great job of reading my mind and filling in the gaps.
You are a good little dinosaur. Smiley Wink
Ben
Message 7 of 21
(4,262 Views)
Dinosaur?  I'm not that old.  Oh, you may be referring to my avatar. It is actually The Cheat.
GCentral
Message 8 of 21
(4,252 Views)
Hi All, I run it again and did not find the error. Attached is the sub vi. You guys are correct, it seems like the running of this subvi was not completed sometimes. When it steps out, the runnng has not been completed yet. Please advise what should I revise! Thank you very much!
Message 9 of 21
(4,225 Views)
It's hard to tell, but you might have a race condition.  Where is the VISA Resouce coming out of inside of the Diagram Disable Structure?  If it is connected to the property node, then you have a race condition.  Please attach a snippet or the actual VI to make debugging a little easier.
GCentral
Message 10 of 21
(4,220 Views)
