02-01-2006 12:05 PM
03-07-2006 08:50 AM
03-07-2006 11:34 AM
03-08-2006 08:41 AM
10-19-2006 01:22 AM
07-29-2010 04:26 AM
Hi Karl,
I have read your posts regarding the PR4000.
I am trying to communicate with a PR4000 single channel device via Labview vis which I found on a German website.
You mentioned that a colleague was able to help you with this and you succeded in developing a program for it.
I wonder if you will make this program available publicly but if not could you please give me a start with the codes which you have used to get measurements from the PR4000. (I have found the PR4000 manual very confusing).
I pressume that you are using Express I/O vi to achieve this.
I look forward to hearing from you,
Nevica
08-04-2010 08:02 PM
Hello Nevica,
It has been a long time since I looked at this problem, and I've since moved on to other labs, leaving the program and the device behind, so I no longer have it myself.
The techniques that I found most useful were to use the most basic techniques to send messages to the device, for example through the NI MAX application you can send individual commands. I don't recall if it responded to a *IDN? query, but that's always something to try. You may be able to contact MKS and get the full list of commands that you can send via RS-232, and develop your own driver through NI VISA. First make sure you can get a response out of the device, then write a short program to query it, or adapt the vi's you've found to connect to it.
I hope this helps. Good luck!
Kar
