A problem about LabVIEW calling C program
After compiling the DLL dynamic library file, I call the C program through the "call library function node". However, after selecting the file, the following problem occurs:
Prompt: the selected file is not a legal library.
I don't know what the problem is. I hope I can get your help.
(1,949 Views)
Is this on the same system that you used to compile the DLL?
Is this really a C(++) DLL or rather a .Net assembly?
Even Dependency Walker claims that it is not a valid COFF PE file format. So something in your build steps is very much wrong.
If you open the DLL file in a text editor it simply is an INI style file!
Rolf Kalbermatter  My Blog
(1,943 Views)
Are you using Windows OS?
Is your dll built on Windows?
George Zou
(1,909 Views)
