Logging example using custom events
This is my first real attempt at creating an example VI that's actually useful.  🙂  The idea was to create a logging function which can run separate from the user control loop and can be called from anywhere when needed.  In our ultimate application the logger will store logs from everywhere and then dump everything to a file after all testing is complete.  Some links to info I used in creating this VI:
https://www.ni.com/docs/en-US/bundle/labview/page/creating-custom-events.html
https://flylib.com/books/en/3.352.1.101/1/
https://forums.ni.com/t5/LabVIEW/Event-Structure-prevents-button-from-working/m-p/4250587#M1236699
It seems to work fairly well.  Although I'm not completely happy with the way the error clusters run.  Any ideas on how I could synchronize the termination of the two while loops?
What do you think of this solution?
(4,467 Views)
Add another user even with just a boolean to send the terminate event to all loops.
Santhosh
Soliton Technologies
(4,425 Views)
Accepted by topic author arcadebench
I think you did a very good job for your first "real" vi!
A modified version of your code is attached to give some ideas on how to clean things up a bit.
For your question about error handling:
Functions like Create User Event or Register For Events don't fail at runtime so I don't handle them.
File access and Hardware errors do need to be handled well and should not shut down the vi.
At a minimum a Simple Error Handler should be used so the error is displayed before the program closes.
Founding (and only) member of AUITA - the Anti UI Thread Association.
(4,391 Views)
Some outstanding changes!  Thanks for taking the time to review this.  I really like how the clusters are used to clean things up.  Adding the Init and Quit/(Exit) events seems like it would be ubiquitous and useful enough that they would be built into LV.
A few questions if I may:
*  For the lower loop I noticed that you didn't include "Destroy User Event" for the Init nor Quit events.  Is this optional?  Would they be necessary if for instance the VI was a pop-up window where the application wasn't exiting upon Quit?
*  Is the Coerce To Type needed for the array initialization?  Wouldn't the Initialize Array already output a 1D array?  Just trying to understand the nuance there.
*  For the Quit Event you mentioned that you normally pass a variant with Address, Command, and Data.  Can you give a use case where that would be useful?
(4,363 Views)
I would still put it outside the loop to destroy the event
Since he is using bundle operation (not bundle by name which requires a cluster definition), the cluster data type uses the default name for the 1D string array, instead to give a custom name, he is type casting it, now during bundle operation it will take the "Log Array" as the element name.
Santhosh
(4,351 Views)
To be honest, I never use the Destroy User Event function. After dozens of systems (some that run for 1100+ hours
continuously) this hasn't caused any issues.
Santhosh is correct. This is a way to give a name to a wire. And as he mentioned, there are other ways to handle this.
It's good to be aware of different ways to do things.
This is intended to be a low speed messaging system (all vis get the messages - but only respond to their name and the
special "All" address). I call it the "GP Event" (General Purpose).
The ability to Open, Close (front panel), and Quit (end) a subvi is the most fundamental use. If the Event Loop controls a state
machine (daqmx, serial, camera) then it is responsible for stopping that state machine.
If a vi adheres to this made up standard, I can drop it on the block diagram and know it will play well with the rest of the code.
But this is just the beginning of the possibilities. You can control program operation, send info, and send/receive data just to
name a few options.
A simple example is attached (back saved from LV 18 to LV17).
(4,310 Views)
