A problem in DAQ
Hello,I have a problem with the DAQ support because the PC is not detecting it when I use LABVIEW 2015, and it does not display the temperature modules. A message saying 'No supported devices found' appears
(1,669 Views)
What is the model of your DAQ device?
What is your NI-DAQmx version?
(1,656 Views)
Also, the screenshot you show is the second page of the Express VI setup.  What did you select on the first page, where you have to choose from a tree starting with "Acquire signals"?
(1,630 Views)
You probably should mention what OS you are using,  that you are using the 64bit version of LabVIEW 15 (the Icon is a clue on you screenshot) and what version of NI-DAQmx you have installed and, the device model number. without all of that information we cannot read the specific DAQmx ReadMe file for you.
You can find ReadMe files for all old versions of the NI-DAQmx Driver Here and the specific ReadMe file should be installed on you machine with NI-DAQmx.
(1,599 Views)
