A problem taking images with a PCI 1409
Hello all, I've a CCD camera throug I try to acquire images by a PCI 1409 card. Im configuring the device throug MAX and seens to work fine, but when I'm using the snap block or minor level I cant see anything, the image turn black. I've search in other forums and I've found that the moving the range it can be fixed, but even changing this, the image does not change just take a solid gray escale color. I taked some screen prints.
If someone can give a hand with this, I'll really appreciate it.
Many thank,
Andrés Felipe Gómez
(2,642 Views)
Just use init acquiure close and nothing else.Dont dipose the image in the end.U have created this from vision assistant i suppose.I suggest u not to do that.For aquire define a buffer.Dont use buffer list etc now.Just the 3 commands mentioned above will work.Make sure u have specified the port correctly.Just right click on the image go to palate and make sure it is in gray scale and not binary.Lemme know
Enjoy labVIEW
(2,615 Views)
Hello, I did it, but i have the same problem I look in other forums about the conversion method but it doesnt works. I dont know what happend.
Always a solid color (grayscale) image appear . 😞
Thanks for help.
Mensaje editado por Anfego
(2,545 Views)
