avi compression
hi everyone...... the example avi compressor comparison.vi, i am using to it compress a avi file but then when i used the compressed file to run again using avi pallate ,the avi close.vi givies error "incorrect avi format". is there anyway to get rid of the error??
Regards
(3,182 Views)
Can you post the vi nolsqn?
(3,172 Views)
Hi nolsqn,
Dose the problem occur when you try to open it in another VI?  Or is it happening withing the Compression VI?
Adam H
(3,137 Views)
