A question about units
Hi all,
I wanted to ask about robootics VI's.
What are the units I should use in "create steering VI" for the wheel seperation and in "create wheel VI" for wheel radius?
I've attached pictures with the help data.
I use labview 2015
Thank you so much
Orit
(2,085 Views)
Accepted by topic author unita
@unita wrote:
Hi all,
What are the units I should use in "create steering VI" for the wheel separation and in "create wheel VI" for wheel radius?
I use labview 2015
Thank you so much
Orit
It probably doesn't matter.  If it does, it would relate to any other functions in this library that aren't attached such as something like a velocity calculation.  Just be consistent in what your measurement units are.  So if you use inches, use inches everywhere.  It seems the subVIs work on ratios.  So don't mix inches and feet.  If there is a velocity function that you enter feet/second into, then you probably want to use feet in these subVIs
(2,051 Views)
