How to Update NIDrivers
how i can fix this http://prntscr.com/r6n35q
operating system opensuse leap 15.1
(3,255 Views)
Please attach images directly here. Linking to third party sites (peppered with ads!) just to show a picture is highly discouraged.
(3,237 Views)
(3,182 Views)
Are you in the process of manually updating your Linux system, including the kernel?
If so, how did you go about updating the kernel?
I suspect you might have changed something that NI would prefer you not... or at least, you didn't use the intended process.
There are some instructions in your image as to possible further steps, but perhaps it's better to assess why you're updating in this way if that is the case (and if it's necessary).
If not, you might find it easier to simply reinstall from a recovery setup.
(3,164 Views)
the problem occurs when i want to open a vi and when i was looking for the error message it came up that you should update it like this
(3,159 Views)
because when i want to open the vi it says what i it is displayed on the following screenshot
(3,152 Views)
