A set from a set of sampled data from a thickness sensor.
The samples are stored in an appropriate array of up to 100 elements.
The values represent the depth of the insulation around a particular cable.
The thickness can vary from 0-4mm represented by a corresponding real value
stored in the array. as long as the depth is between 1 and 4 mm the cable
falls within the allowable specification however if it falls below 1mm it is
deemed to be too thin.
Design a VI that will identify the number of thin values and display as a
percentage of total number of samples.
The front panel  have the must have the following:
An array of controls holding the sampled values.
An indicator holding the percentage of thin values.
(4,416 Views)
Why are you posting your homework here ??? Shall we comment on how we think about your assignment. Well it is a an easy and straight forward task.
PS.  My teacher always told me. If you find the answers by your self you will remember it far better:smileyvery-happy:
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(4,412 Views)
why did you put the same function in the true/false stracture? for more help let me know..
(4,367 Views)
hi there, this is Faddi, I am doing the same assignment as the one you poested earlier!! I know its a very basic one, but i need your help in doin the second task asap PLEASE!! IF you could please...its as follows:
This is to be designed to work on a set of sampled data from a thickness sensor. The samples are stored in an appropriate array of up to 100 elements. The values represent the depth of the insulation around a particular cable. The thickness can vary from 0- 4 mm represented by a corresponding real value stored in the array. As long as the depth is between 1 and 4 mm the cable falls within the allowable specification however if it falls below 1 mm it is deemed to be too thin.
Specification 1
 To design a VI that will identify the number of thin values and display as a percentage of the total number of samples. The front panel must have the following:           An array of controls holding the sampled values.           An indicator holding the percentage of thin values.
Specification 2
 Thin values tend to appear as sections or patches along the length of the cable i.e. values of less than 1 mm stored in successive array elements. To design a VI that will meet specification 1 and will also calculate the number of these thin patches. The front panel will now have an extra indicator to display the number of patches.
Thankyou
(4,326 Views)
hi,
im still stuck with this assignment...could any one help me plz?
(3,832 Views)
hi,
i need help in doing this assignment...could you plz help me?
(3,830 Views)
We will not do the assignment for you.  If you have specific questions about some part of your program, we will answer those.  To get help here for a school assignment, you need to show what you have tried, explain what is not working the way you think it should, and ask a specific question.  For example a question about why does my data file only contain one line of data might get an answer which points out the the Write to File function was set to overwrite the previous file.  A questions which asks how to acquire the data and write it to a file would likely not be answered at all because it would do the assignment, or it would be answered by suggesting that you study the examples which come with LV.  I hope you can see the difference.
Lynn
(3,825 Views)
