A simple puzzler for the long (US at least) weekend...
Now for something (related, but) completely different!  What if you use the Extended Precision type (whose details are, shall we say, a tad murky)?Altenbach's FloatsAltenbach's Floats
You get yet another number!  If you assume that the three lowest bits are thrown away (why?), it's correct, but the Dbl representation is "closer".
Remind me to stick with "reasonable precision" (i.e. Biology, not Physics) ...
Bob Schor
Message 11 of 15
(841 Views)
In LabVIEW 2011 32 bit it was I32 limit, not I64:
Message 12 of 15
(789 Views)
Thanks, fellow LabVIEW devs - this was fun to follow along!  🙂
Bill
CLD
(Mid-Level minion.)
Message 13 of 15
(761 Views)
Bob Schor
Hmm, shouldn't Extended precision have more ... precision?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 14 of 15
(733 Views)
/Y
I'd say in this case it is "as good as"
Bob's comment about the obscurity of the EXT number format is based on this:
https://zone.ni.com/reference/en-XX/help/371361R-01/lvhowto/floating_point_numbers/
https://zone.ni.com/reference/en-XX/help/371361R-01/lvconcepts/how_labview_stores_data_in_memory/
Extended-precision floating-point numbers have an 80-bit IEEE extended-precision format.
Note  In some cases, extended-precision floating-point numbers can have a 64-, 96-, and 128-bit IEEE extended-precision format depending on the computer processor. 80-bit is the most common.
Message 15 of 15
(685 Views)
