A strange question when configuring a Gige camera with IMAQdx.
Sorry for the late reply. Our camera is placed in the farm far away from laboratory, I waited until today to test it again. I just found the same case also happened to the module of "IMAQdx get image data", which means if running normally,  nothing was received, but it worked well in the mode of " Highlight Execution" even if switching to the normal mode later......
Message 11 of 18
(1,485 Views)
As mentioned before this indicates a timing problem of the camera. You need to place some delay either between opening the camera and setting the property of between setting the property and first trying to grab a picture or maybe even both.
Rolf Kalbermatter  My Blog
Message 12 of 18
(1,480 Views)
Recently, I encountered the same problem in a labview program for GPS as shown below. I solved this question by inserting a time delay module before the .net property node. So, I believe such a question comes from the property module rather than the IMAQ modules.
Message 13 of 18
(1,463 Views)
If I Understand correctly this is what you are doing:
-When Highlight Option is disbaled Open the camera and set the attribute and then Capture continuously
-When Highlight Option is Enabled, Open the camera and set the attribute and then capture continuously.
-Now do you change the attribute after running the VI or it stays at 201?
-For every grab if the shutter needs to be open and closed then that property node needs to be inside the loop.
-Check the Grab and Basic Attributes.vi example which is shipped along with Labview and post if it is still same behaviour.
-What is the camera make and model you are using?
-Also what is 200 and 201 units?(milli seconds or micro seconds?) and check camera manual to see how much time it actually takes tp open the manual shutter.
uday
Message 14 of 18
(1,455 Views)
The signal moise ratio of this post is pretty low. The OP’s problem was indeed IMAQ but more specifically the camera. Yours is VISA and not .Net. The problem in both cases appears to be with the external device connected to the respective interface. And that’s not very strange. External devices are often many magnitudes slower than a modern Intel Core based computer. So it’s very possible that you simply overrun the device when you try to do things to fast.
Especially since you use the Bytes at Serial Port property, which as I have stated in many other posts here on this forum, really has absolutely NO business of even being present in 100% of instrument control software.It's not the right thing to use in every single instance of a VI that is meant to talk to an instrument for automation control since it makes the whole communication completely dependent on the execution speed inside your computer, which is what you want to avoid at all cost.
If you talk to an instrument you either receive a fixed sized amount of data back, either as complete message or a header that contains the amount of data that is to follow, but in most cases you receive an answer that is terminated by a special character, most often a carriage return or line feed. VISA provides the means to let the VISA Read function terminate on such a character and your Initial Serial Port VI that you use in your code even configures the serial port to use this feature with the line feed character by default. But you can reconfigure that through the "termination char" input. With that enabled you simply need to pass a big enough number of characters to read to the VISA Read function that is guaranteed to be bigger than the longest expected answer, et voila: VISA Read will then sit and wait there until one of four things happens:
1) a VISA error has occurred somewhere in the driver, which is then returned
2) The specified timeout has occurred, returning a timeout error
3) the amount of data you requested has arrived, returning a warning that you received the expected amount of data and there might still be more present in the input buffer
4) the specified termination character has been encounterd in the data stream
Et voile, no Bytes at Serial Port necessary at all as long as the device responds in the time you specified as read timout to the VISA Read.
But other than the race condition introduced here by the use of the Bytes at Serial Port property, it hasn't a lot to do with the original problem in this thread.
Message 15 of 18
(1,447 Views)
To be honest, I have learned a lot from you and thank you so much.
Actually, the posted question has been resolved by adding the time delay module based on your suggestion. However, I had to add it in front the property module.
Also, our camera is 12-bit camera similar to CCD. This is why only half of image appeared as I mentioned in the former posts.Could you please give some advice on how to log 12-bit images? Thanks in advance.
Message 16 of 18
(1,420 Views)
Message 17 of 18
(1,411 Views)
Message 18 of 18
(1,408 Views)
