A510 VFD Modbus RTU via RS485_DI state values in register
I have a Teco Westinghouse A510 VFD which i am controlling a 3phase motor/hoist and I am controlling using the Modbus Library via RS-485 and using serial com RTU.
I am getting the motor to spin and write to the registers, however, I am having difficulty reading a particular register with multiple bits that I need to access on the same register, see the images below (Modbus Com manual for VFD). I have uploaded my vi below and also the modbus manual for the VFD for reference.
I need to access the DI state to read if they are open (0) or closed (1). Also, does the Modbus API control the CRC check or do I need to include that somehow, if so how?
Any help would be greatly appreciated.
Message 1 of 8
(2,132 Views)
Accepted by ikhan123
Read the register 2522H. It should return a U16. Then convert the U16 to Boolean array.
Modbus Library will handle the CRC.
https://tmesystems.net/
Message 2 of 8
(2,100 Views)
Hi ZYOng,
much appreciated.
Thanks.
Message 3 of 8
(2,074 Views)
I also want to write to a register with multiple bits as in the above example but instead of reading a list of booleans, how would I write-to or read non-boolean from a sub-register?
Please see the figure below, how would I write to register to 2501H bit F to turn the Torque command set by Communication: ON
Thanks for any help and support.
Message 4 of 8
(2,066 Views)
Message 5 of 8
(2,057 Views)
Bit F is the 15th bit (using 0-indexing).
Similarly you can use Boolean Array to Number to get the U16 value.
Message 6 of 8
(2,050 Views)
thanks, it worked!
Message 7 of 8
(2,034 Views)
Hello ikhan123 and eveyrone else active on this thread.
I just received the same VFD (E510) from Teco Westinghouse and I am struggling a bit to get it to receive commands through ModBus RTU.
My set up is:
 - The VFD connected to a covneyor belt (and verified to work, since I can control the conveyor using the keypad).
- A CAT 6 cable connected to the female RJ45 input designated for the ModBus RTU communication on the VFD and connected to my laptop, via an RS485 to USB adapter.
- I have changed the Main Run Source Command Source Selection (00-02) from the factory setting of 0 to 2 which should indicate RS485 communications as the command source.
I have tried some python scripts on my laptop and also using QModMaster on windows, but I was always getting timeouts, not being able to read or write on in of the registers.
Is there something else I need to do to able to send/receive data through the RS485 interface? Is there a part on the set up proccess I ommited?
Any suggestions are welcome and much appreciated.
Message 8 of 8
(151 Views)
