AC/DC coupling in LabVIEW
Hello all,
              Need help. I have used  AC coupling for voltage acquisition in LabVIEW for NI 9215 earlier but now I am unable to use it. I have to remove AC coupling. When I select AC coupling. A message pop-up that shows DC coupling is possible. Where is the wrong.
LabVIEW 15
DAQmx 15.5.1
Message 1 of 13
(4,941 Views)
Accepted by nagesh15
Hi nagesh,
What's wrong here?
According to the datasheet the NI9215 does not offer any "AC coupling" (atleast I didn't find it mentioned in there).
So what do you expect here?
Message 2 of 13
(4,920 Views)
But I have used AC coupling in 9215.
When I am taking data using no AC/DC, I am getting offset in signal. Is that always give offset with AC/DC coupling
@GerdW wrote:
Hi nagesh,
What's wrong here?
@GerdW wrote:
Hi nagesh,
What's wrong here?
Message 3 of 13
(4,914 Views)
Hi nagesh,
The datasheet does NOT mention any "AC coupling" for the NI9215. DAQmx also says "no AC coupling available".
But you insist on using AC coupling? I don't see any option for that…
Message 4 of 13
(4,910 Views)
Put a capacitor in series with the input to block any DC offset.
BTW: That's exactly what "AC Coupling" does in an oscilloscope.
=== Engineer Ambiguously ===
Message 5 of 13
(4,884 Views)
Hi nagesh,
I guess you already know how AC coupling is implemented.
When NI hardware supports such a feature then the datasheet will also mention the feature explicitely - like NI does for the NI9232 module…
Message 6 of 13
(4,880 Views)
Thankyou for reply.
1. Why it used AC coupling in NI 9215?
2. Does 9215 gives offset during aquisition with no coupling selection? I am getting offset but when I selected AC coupling I am getting no offset.
 Please , explain.
Message 7 of 13
(4,876 Views)
HI nagesh,
  1. We don't know, it shouldn't offer AC coupling for this hardware…
  2. What "offset" are you talking about? Why do you get "no offset" with AC coupling enabled when your DAQmx/VI says it does not support AC coupling?
All the time you missed to attach your VI and some measurement results when we discuss about your hardware and the options it does not support…
Message 8 of 13
(4,831 Views)
@nagesh15 wrote:
Thankyou for reply.
 Please , explain.
#2 - Basic electronics.  Serious question: are you sure you're qualified to be operating this equipment?
Bill
CLD
(Mid-Level minion.)
Message 9 of 13
(4,827 Views)
Blue curve is with No AC/DC coupling and red curve is for AC Coupling. These signals I got using same NI 9215 and same time back to back.
Message 10 of 13
(4,817 Views)
