ACQUIRE SPECIEFIC DATA STRING FROM A STRING INDICATOR
HI I AM NEW IN LABVIEW. ALL I WANT IS TO ACQUIRE SPECIFIC LINES OF STRING FROM A STRING INDICATOR_1 AND PASTE IT TO ANOTHER INDICATOR_2.
THERES A LOT OF DATA IN THE INDICATOR WHEN EXECUTING THE PROGRAM AND I NEED TO GET ONLY A COUPLE OF LINES FROM THAT STRING INDICATOR1.
SOMEBODY HELP PLEASE..
IF I AM NOT CLEAR TO MY PROBLEM STATEMENT PLEASE FEEL FREE TO CORRECT ME.
NEED HELPING HANDS FROM LABVIEW MASTERS. 😃
(3,385 Views)
How is the program supposed to know what parts of the string should be selected?
(3,349 Views)
HOPE THIS HELP YOU SIR TO UNDERSTAND MY PROBLEM..
(3,335 Views)
THE CLOSEST SOLUTION I CAN THINK OF IS TO USE "PICK LINE FUNCTION"
(STRING>ADDITIONAL STRING FUNCTION>PICK LINE).
BUT STILL I CANNOT USE IT BECAUSE PIK LINE FUNCTION REQUIRES "LINE INDEX" AND IT IS IMPOSSIBLE TO KNOW THE LINE INDEX.
(3,330 Views)
Please fix your caps-lock key. It seems stuck! (see also)
It is still not clear what line you want. What parts of the desired line is fixed and what parts are variable?
(3,319 Views)
I think you have to give us an example. Which text is supposed to be in your Indicator1 and according to that which lines should be extracted? And why these lines?
Greets, Dave
(3,292 Views)
@1der-er, @altenbach is asking the most crucial question here.
We need to have more detail about these two strings that you are working with.
Please answer the following questions:
What is the data in HYP_1 that you need to paste to HYP_2? is there any pattern? what do the lines that you need to extract have in common? what differentiates them from the lines you don't intend to paste on HYP_2?
(3,267 Views)
