FDTI chip NOt found, show LCD 3_3 Interface UUT not found.
Did any one see this problem for FTDI chip?
 (1) I install the ftdi2xx driver, it was running fine.
(2) in the WIN, device manager, you can see the  USB  device.
I attached the picture.
please let me know .
Thanks for help.
(2,545 Views)
In the following link there are some LabVIEW examples that you can run in order to see if your driver is working correctly,
http://www.ftdichip.com/Support/SoftwareExamples/CodeExamples/LabVIEW.htm
Also, this is not a NI driver. Have you tried to contact FDTI support? this trying to have more information about this error.
MJR.
(2,501 Views)
