AD8497 Amplifier connection to thermocouple
Recently I have been trying to connect my K-type thermocouple to the NI 6009 DAQ. However I noticed that the signal obtained was not pretty accurate so I acquired a AD8497 (http://www.analog.com/static/imported-files/data_sheets/AD8494_8495_8496_8497.pdf)
As you will see in the pictures attached I (think) managed to wire according to the circuit shown in the datasheet. However when trying it with LabView I do not obtain a reasonable value for the temperature, however I got a voltage of approx. 1.38 V which according to the multimeter measurement it is pretty good.
So I am hoping someone can help me with that, since I do not see any other way to obtain temperature measurements from 6009 than the one I am using, and I think everything is correct.
JLocke
Message 1 of 8
(4,971 Views)
How have you configured the DAQ...?? Is it RSE or differential?? Can you share the VI or only part of code which is responsible for data acquisition.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 2 of 8
(4,965 Views)
I configured RSE.
Here I attach the file. The main aim is to drive a heating tape according to a setpoint temperature. However the temperature measurement has some problem I cannot solve.
JLocke
Message 3 of 8
(4,962 Views)
I'm not sure which should go to the 'Ground' terminal of USB DAQ... Should it be NEGATIVE SUPPLY or SENSE..!!
are you able to read correct voltage using a digital multimeter, try read the output of AD8497 IC with respect to SENSE terminal.
Message 4 of 8
(4,947 Views)
well, according to the datasheet, both the SENSE and OUT are wired to the AI channel of the DAQ, therefore I am wiring the reference to the GND of the DAQ as well. I am reading around 1.4 V from that, which to me is WAY too big! That's the problem, since I should expect around 240 mV to get ambient temperature but I do not.
My main concern is about the wiring or the DAQ itself, because I think is not that complicated to integrate the circuit with LabVIEW isn't it?
JL
Message 5 of 8
(4,944 Views)
I think connection to USB DAQ card should be..!!
Connection
Message 6 of 8
(4,937 Views)
But don't you think I should ground my power supply or so? how about the reference pin?
Message 7 of 8
(4,925 Views)
I did that as you said and in my case the voltage output now is around 300 mV which is similar to expected, however the temperature is not (using the VI file been attached), are you sure it is not missing anything else?
Message 8 of 8
(4,919 Views)
