ADODB._Connection and RecordCount
I need some help in getting RecordCount to show positive value. Please find attached Untitled2.vi. Right now it keeps coming up with -1. Thanks.
(5,198 Views)
Find attached VI.
As ADO help states, "The cursor type of the Recordset object affects whether the number of records can be determined. The RecordCount property will return -1 for a forward-only cursor, the actual count for a static or keyset cursor, and either -1 or the actual count, depending on the data source, for a dynamic cursor."
Thus, you have to change the cursor type (when your Recordset is closed, otherwise it produces an error).
Hope this helps.
p.s.: use one "Move First" before that loop in order to avoid the case structure inside.
(5,198 Views)
Thanks. Your suggestion helps.
(5,198 Views)
Please how can I get a copy of the ADO help you mentioned? Thank you.
(5,198 Views)
If you right click the "RecordCount" property icon, you have an entry for its related help ...
Hope this helps
(5,198 Views)
I tried the right click but nothing came up. I'm also trying to re-install the package. If this doesn't help then I will resolve to getting the document elsewhere. Thanks.
(5,198 Views)
Try to right click the bottom part of the icon (above property name - as shown in attached picture ... ). If there is no entry for help, take a look in Windows' folder, Help subfolder and try those files starting with "ado" (should be Ado210.chm). If you cannot find it, email me at labviewer@yahoo.com and I'll reply to you the help file.
Good Luck!
(5,198 Views)
