Reading from the Database
Can anybody give a rookie a detailed example on how to read the value
from the database by criteria.
I've been trying to use ActiveX. No problem using DoCmd.RunSQL to
write to the database. However, no any known method, like DoCmd.RunSQL
"Select...." or opening the recordset does return a value.
And no, I do not have LabView SQL Tool, and no, I do not want to spend
additional $500 to purchase ANYTHING else. It is my understanding that
LabView MUST have a standard ways ( maybe not as straight as with the
SQL tool ) to read a value from the database.
Thank you for the help!
(3,176 Views)
Jeffrey Travis has started L.O.S.T. (LabVIEW Open Source Tools) and one of the first tools he has created is LabSQL. This uses an interface to ADO to issue SQL commands. You can download it from http://www.jeffreytravis.com/lost/.
(3,176 Views)
I've tried to use Jeffrey's L.O.S.T. but I keep getting "SubVI is not executeble" error. Please do you know what's responsible?
(3,176 Views)
Which subVI and what is the error for the bad subVI? What version of mdac/ado do you have on your system? What OS are you using?
(3,176 Views)
1. SubVI: Example-Fetch a Table.vi
2. Error: 'Example-Fetch a Table.vi' is not executable
SubVI's within this VI have the same error as well
3. ADO Version: Microsoft ADO 2.1
4. OS: Windows NT 4.0 SP5
(3,176 Views)
Keep clicking on the broken VIs until you get the detailed error. I suspect that you'll have to go down a ways until you get to ActiveX stuff.
(3,176 Views)
