ADODB and DotNet
Does any one ever use ADODB with dot Net.  I have create a function to get stored procedures list from SQL. I alway got an error as "specified methode not found".  I have succesfully doing this using Active X.  Don't know what go wrong with Dot net.
I included the vi below.  Thanks for all the help.
Message 1 of 9
(5,698 Views)
Hey Tphan,
Where in the code are you getting this error - is it in the Execute method?  Is there an errror number that comes with the message? What version of the .NET framework do you have installed on your machine?
Misha
Message 2 of 9
(5,663 Views)
Thanks for respond to my post.
Yes, It is in the execution methode- with error 1316 which labview explained as "Specified method not found."
I have Microsoft.Net Framework 1.1, 2.0,3.0 and 3.5 installed in my computer.  The file "adodb.dll" in the folder "\program Files\Microsoft.net\Primary Interop Assemblies\" is what link to show a version of ADODB(7.0.3300.0) When I link it to the contruction note.
What is strange is that When I right click on the execution,  The properties and methodes open up with many duplication such as 3 open methode, 3 close methodes...
I must have somthing very wrong.
Tuan Phan
Message 3 of 9
(5,640 Views)
Hey Tuan,
You can check the version of the ADOdb assembly from C:\WINDOWS\assembly (you should see 7.0.3300.0 there)
I'm not exactly sure what you mean by duplicate properties and methods - can you post a screenshot?
Misha
Message 4 of 9
(5,621 Views)
Hello Misha,
Sorry for not reply right away.  Iwas busy doing something else.  Anyway,
yes, it does show 7.0.3300.0 in the assembly folder.  Here is the screen
 for that screwup propertyof the recordset.
Message 5 of 9
(5,611 Views)
I forgot to mention that I used LV8.5 professional version.
 Tphan
Message 6 of 9
(5,610 Views)
Tphan-
I have opened your code in LabVIEW 8.5, 8.6, and 2009.  Each environment, the same behavior occurs.  Therefore, I believe this is a new issue and I will report it to R&D (CAR #180836) for further investigation.  I did notice that is only occurs at the “Recordset” and “Connection” Nodes.  I also noticed when one of the parameters is selected, it chooses each instance therefore not messing up the code.  It is simply unexpected behavior.
Mike S
NI AE
Message 7 of 9
(5,584 Views)
Smiley SadBummer...I got a dead end here until problem solved.
Thanks for your support.  Hope to hear back from you soon.
 Tuan Phan
Message 8 of 9
(5,579 Views)
Tphan-
Please post back to this thread to request any status updates on this CAR.
Mike S
NI AE
Message 9 of 9
(5,567 Views)
