ADXL345: Convert 16-bit Twos Complement to 10-bit Signed Int
Hi All:
I was hoping I could find some sample code on how to convert data from an ADXL345 accelerometer.  I am reading acceleration data from an accelerometer through a PIC MCU into a LabView program on my laptop.  The data from the sensor is formatted in two bytes, say axDataLO and axDataHI, forming a 16-bit twos-complement value.  This value represents the result of a 10-bit ADC that is right justified with sign extension.  If I am clear, the sign exension means that the last 6 bits are padded with either a 1 or 0 depending on the sign of the data.  How do I convert this data into a signed integer?  Any help is greatly appreciated!  Thanks.
Message 1 of 10
(8,267 Views)
this probably has been asked before, but anyway:
Message 2 of 10
(8,266 Views)
Accepted by jcalusdi
Hi GerdW,
Thanks for your reply.  Yes, that was what I needed, as well as, fixing a bug in the code of my PIC microcontroller.  I have included a code snippet here in case someone out there is working with the ADXL345. Thanks again for your help.  V/R James C.
Message 3 of 10
(8,239 Views)
Hi jcalusdi,
another try:
The array(U8) should contain your 6 bytes delivered by the ADC...
Message 4 of 10
(8,227 Views)
Thank you, again.  James C
Message 5 of 10
(8,222 Views)
Awesome code! Just what I was looking for. Thanks!
Edgar Cabrera
Certified LabVIEW Associate Developer
Message 6 of 10
(8,014 Views)
Hi all. Could I know why the input of "Join Numbers" are crossed? Thanks for the answer.
Regards.
Message 7 of 10
(7,473 Views)
Hi Corci,
read on Wikipedia about big or little endian(ness)...
Message 8 of 10
(7,471 Views)
Thank You for the rapid answer. I've read online documentation about Little and Big Endian. How do I relate the information on the datasheets of the ADXL345 with this concept? Does "Left-Justified" means Big Endian?
Thanks again. Regards.
Message 9 of 10
(7,462 Views)
Hi Corci,
the endianness dictats which of those two bytes contains the MSB and the LSB. You have to connect the correct byte to the high and low input of JoinNumbers...
Message 10 of 10
(7,442 Views)
