AI_Start providing a trigger pulse?
Can AI_start.vi be configured or modified to provide a one pulse output per analog sample? Or is there a better VI to use? I'd like to do a buffered analog capture and provide one DO port pulse per sample to trigger a high-speed camera.
(2,656 Views)
Greetings,
Yes, you will be able to obtain this behavior. The signal you will need to use is the analog input sample clock, which is referred to in LabVIEW as the STARTSCAN signal. The following KnowledgeBase explains how to use Route Signal.vi to output this signal on PFI 7:
How to Use the WFTRIG, UPDATE, or STARTSCAN Outputs of an E Series DAQ Board
Good luck with your application.
Spencer S.
(2,656 Views)
