AI sample channels conversion for DAQmx
Does anyone know the equivalent DAQmx VI to replace AI sample channels? Or does anyone know exactly what AI sample channels is supposed to do? I am going through some old code trying to convert it over for use with the DAQmx and can't figure out how to replace this VI. Any help is greatly appreciated!
(3,226 Views)
Posting your code would be easier. I would also look at the analog acquisition examples in the example finder built into LabVIEW.
Tim
GHSP
(3,220 Views)
Thanks for the examples suggestion, as it seems DAQmx Read is a good substitute!
(3,200 Views)
The DAQmx Read is your only option. The key is getting the correct polymorphic instance.
(3,183 Views)
