LabVIEW program to burn in IC
Hi friends,
                Can anyone guide me to burn a progem (a siple calculator program) to burn into a IC ?
I have done coding of a simple claculator. Now I want to burn it into IC and interface it with a small disply to give it an exact calculator look. Which IC can be used for this purpose? What will be the burning software?
(3,794 Views)
I don't understand what you are asking. Is this a LabVIEW program that you've written? By IC are you referring to a microprocessor or and FPGA?
(3,760 Views)
using microprocessor.
program coded in labview, in windows platform. now how to use this program to make a pocket calC?
(3,754 Views)
Did you read the information at the above link before you posted your last question?
(3,750 Views)
