AML Toolkit DBScan
Hello
Does anyone have experience with the AML toolbox. Clustering with dbscan gives me -1 in the predicted labels. Do not know exactly what the algorithm wants me to say. Are those labels which can not be assigned?
greetings ecrofx
(3,759 Views)
  • There is absolutely no reason to put the your message body inside code tags, right?
  • Since you posted in the LabVIEW forum, I am assuming that your question is somehow related to LabVIEW. Maybe you can add a few more sentences to explain that relationship so we can at least attempt to help. (See also below)
  • It also always helps to spell out acronyms, for example AML can mean a lot of things. 😉 (A link often helps)
(3,737 Views)
Yes, this is the LabVIEW Analytics and Machine Learning Toolkit.
My bad for the code tags, was not intended.
Here a screenshot of my VI. It works, in the case structure are kmeans and GMM also implemented. They both work fine.
So i think DBscan should work also fine. I have no errormessage or something.
I only dont know why Dbscan give -1 Labels as output.
(3,714 Views)
Accepted by topic author Oliver88!
It means the Db-Scan can not assign the Data to a cluster. The parameters not allow it.
(3,688 Views)
