Absolute Time to a Bundled Chart- Please help.
Good Morning,
I have been attempting to add real time to my temperature logging graph however I am struggling a little. I have had a look around and have seen various solutions but I cant make any of them work (because of the Bundle it seems). There are 3 traces on the graph (Y-Axis) plotted against time (on the X). Any help would be amazing im brand new to LabView so sorry its a menial question. Please see some attached photos for a better idea what I am talking about.
(3,453 Views)
You can convert time string to number and send to graph, for example
(3,424 Views)
Thanks for your help but that method looks incredibly complicated and im not sure how to apply it to my situation. Any tips as to how I should implement it. Thank you again sorry im so new to all this.
(3,418 Views)
Accepted by topic author ElectronicEd
You need to use the Waveform data type. You create a waveform with the appropriate t0 value (from the Get Date/Time in Seconds function), using the Build Waveform function, and then you build a 1-D array of waveforms as shown below. Each waveform could even have its own time value.
Marc Dubois
(3,413 Views)
