AO to DI converter for pressure measurement
 I purchased a Digital Input module NI 9422 for measuring pressure using pressure transducer. However, as I understand pressure transducer generate a 4-20 mA analog output , I cannot use DI input module. Is there any way that I can use a AI to DI converter and still use the module?
(3,327 Views)
No clean way. You could see if NI would let you exchange the card.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,295 Views)
Hi skatta,
why do you bought that DI module at all?
While it is better to exchange this module to an AI module you could grab your soldering iron, a little standard pcb and a cheap 8bit ADC IC like the AD670. That way you can still use your NI9422 module to read in the pressure value…
(3,273 Views)
