07-09-2008 09:53 PM
07-10-2008
03:29 AM
- last edited on
10-23-2026
01:50 PM
by
Content Cleaner
Hi orchid,
i think there is no question to use API or VISA, you got the answer here. If you have dll files you can use the "Call Libraray function node". You need a description of the exported functions and then you can build your vi´s.
Hope it helps. Mike
07-10-2008 08:25 PM
07-11-2008
01:50 AM
- last edited on
10-23-2026
01:51 PM
by
Content Cleaner
07-14-2008 09:55 PM
07-14-2008 10:16 PM
The vendor has provided you with some information on their dll's I'm assuming. This is their api and you use the Call Library Function Node to access it. Whatever kind of output you get from the dll should be documented somewhere. You have not provided a link to or the documentation itself so all anyone can do is speculate. You need to go through the api documentation and find the function that returns data from the sensors. Once you have that, it should be possible to plot it.
To get some specific help, you would need to attach the .h file, the .dll, and the api documentation.
07-21-2008 09:57 PM
07-22-2008
05:20 PM
- last edited on
10-23-2026
01:51 PM
by
Content Cleaner
07-23-2008 03:08 AM
07-23-2008 03:08 AM
