APPLICATION BULDER,nilvaiu.dll
Hi
all , i experienced some problem with application builder software, presently iam having LABVIEW 7.1 AND APPLICATION BUILDER 7.1 AND DAQMX DRIVERS 7.3 versions respectively.
I built an exe along with installer , when i run this exe its working fine in my SYSTEM , but when i tried it in an target pc which not having application builder then it has given some problem.
ie since i have 4 vis in that 3 are dynamic vi which uses the DAQmx resources.if i installed the DAQmx drivers in the target pc then it works fine , is it mandatory to install the DAQmx drivers in the target pc.
secondly i changed the installer settings in that i checked the boxs of Hardware configuration , serial port and I/O. and i buid the exe with installer and .nce file (configuration file for DAQmx)this time also its asking for nilvaiu.dll and select library .
kindly provide me some solution on this.
Regards
RAJESH
(3,845 Views)
Yes it is mandatory that you install MAX (measurement and automation explorer) on the target PC. You will also have the DAQ cards configured the same way in MAX as on the development PC.
Joe.
"NOTHING IS EVER EASY"
(3,834 Views)
