Visa Read Timeout Occurs with multiple Reentrant VI Calls
I have written a test application in Labview (6.1) which will be used to test (burn-in) up to 15 serial instruments through a 16 Port USB->RS232 Hub. Here's how it works:
When the App loads, I am transmitting a Connect command to each of 15 com ports (one-at-a-time) using VISA. If I receive the proper response from the unit on that port, I add the port to an array and continue on to the next system. Once I've found all systems on the hub, I wire my array of active Visa references to a for loop in which I open up to 15 reentrant VIs which will run in the background in parallel. Each of these reentrant VIs (all are idential with the exception of the Visa Resource they use) running in the background are sending commands to the the respective instrument and receiving a response. One Function in particular "Get Unit Status" is important and the response determines whether or not the instrument is functioning correctly. Here's the problem -- In my Main Loop, I am continuously acquiring indicator values from each of the reentrant VIs that are running in the background. After a period of time (not consistent) I will lose communication with a port (the symptom is no response from the unit). I've looked closely at the COMM engine I created and found that the Visa Write function is completing without error, then when I perform a Visa Read I immediately get the "Timeout occured before operation completed" error (please keep in mind that this occurs after 100-5000 successful attempts at writing/reading). Eventually another port will drop out, followed by another. This seems to stop occurring and the remaining systems run to completion without a problem.
Some background on what how I'm setting up my Visa Sessions...
When I originally scan for systems (before I load and run the Reentrant VIs)
- Init Visa Port
- 19200, 8, N, 1
- Use Termination = True
- Timeout = 400mS (I've tried larger values already) 400mS should be plenty
- Termination Char=13 (/r)
- Open Visa Session
- Visa Write "CONN18/r" (the command required to connect to my instrument)
- Visa Read with 1 for requrested byte count to read 1 byte at-a-time, concatenating the results until /r is received (or 1000mS timeout occurs -- this is not a VISA timeout) I've also tried 16 for requested byte count and just waiting for Visa to timeout -- both methods work.
Once all 16 ports are scanned I Close ALL of the ports using the Visa Close Function.
It is important to know at this time that I "AM" using proper wiring flow to ensure open occurs before write, write occurs before read, etc.
I'm assuming at this time that all of my Visa sessions are closed.
On to the Reentrant VIs:
Inside each reentrant VI I first Initialize all of my variables and Init/Open a 'New'? Visa session using the same parameters mentioned above.
Then I enter the "Run" case structure where all of the communication begins.
I am using the same Communications Engine to operate the instrument as before (the only difference being that all of the VIs in the comm engine are now reentrant and operate at higher priorities) I have actually saved two different versions of the engine (one for the reentrant calls and one for when I first scan for systems from my Main GUI).
When I init the reentrant VI, I am placing the Duplicate Visa Resource output of my Visa Open Function on a shift register. When I enter the Run case, it takes the Resource from the register on the left, wires through any Comm Engine Vis then back out to the shift register on the right and keeps going for a 12-hour period or until "Get Unit Status" has returned 60 naughty results.
On my Main GUI I am continuously (every 500mS) I am Getting certain Indicator Values from each reentrant VI AND I am also setting some control Values on each reentrant VI. There is no VISA interaction between each Reentrant VI, and the Main GUI.
As I said earlier, up to 15 systems will run for a time, then one will stop responding, followed by another, and another until a few remaining systems will run to completion.
Any advice as to why I'm encountering the timeouts with the VISA read fucntion as I have metioned would be appreciated. I managed to find one suggestion which uses the Bytes at Port function to ensure there is data at the port before doing a Read otherwise, skip the read and retry the whole operation -- I haven't tried this yet.
Sorry for the wordiness of my question. If anyone would like some screen shots of portions of my code (I can't submit the actual code because some of it is confidential) I'd be happy to post them.
Doug.
(3,116 Views)
Hi Doug,
The first thing I would recommend is the solution you have already found, to check and see if there is data at the port before attempting a read. I would be interested to see if this will solve the problem. Does there seem to be any trend to which ports have this timeout error? How many ports does it cut down to before operation seems to continue as expected? Does this number vary, or is it always the same number of ports? I think the best thing to do will be to identify constant attributes of how the error is occurring so that we can narrow it down and see what is going on.
John M
(3,079 Views)
I seem to have solved my problems. I dug deep and found some unwired Visa Error Clusters. It seems that if you don't insert a clean error cluster into the Visa Read function, it will continue to timeout after the first occurence. There were two things causing the problem -- If I performed a read and the instrument had not responded, I would get a timeout error, then every successive read would result in the same error (whether or not data was at the port) because I had not wired the "Error In" cluster. All seems fine now!
(3,071 Views)
