ARM UART interrupt
Hi everyone,
I just received my "Luminary Micro LM3S8962 Evaluation Board?" and I am very surprised to see that UART interrupts seems to be not supported. Is there a way to enable these interrupts in Labview for ARM or another way around? I can't believe you can't use this interrupt at all since it's a crucial feature.
Charles
(4,242 Views)
Hey Charles,
That is correct that UART interrupts are not supported in the LabVIEW 2011 Embedded Module for ARM Microcontrollers. I don't know if there is anyway to enable these interrupts or a workaround but I can check with R&D to see if it is possible. Sorry about the bad news but I will double check if there is a work around or another way to enable these interrupts and get back to you.
David
Applications Engineer
(4,215 Views)
Wow, talk about a bad sales pitch!Smiley Sad
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
(4,210 Views)
I am really disappointed those interrupts have not been implemented along with I2C and SPI...
But thanks a lot for checking!
(4,205 Views)
Hey Charles,
I talked to R&D and they confirmed that there is not a way to implement this. An idea was to use the Bytes at Serial Port VI in a parallel loop with some approriate delay. Sorry again for the bad news. Have a great day!
David
(4,176 Views)
No interrupts ... use pollingSmiley Frustrated
(4,062 Views)
