ARRI Electronic Ballast Driver
I am searching for a VI to communicate with my Electronic Ballast from ARRI.The type is:2,5/4 EB
Does anybody have work with this?
Thanks a lot.
(3,098 Views)
what kind of interface has this Electronic Ballast? USB, RS 232? In the prduct manual i don't see an interface. At ni.com/idnet there are drivers available for more than 7,000 instruments but for ARRI i found nothing.
If you have a USB port then you could try this: http://zone.ni.com/devzone/cda/tut/p/id/4478
cheggers
Sascha
(3,078 Views)
Hy,
The interface is DMX-512 Standard.
I know,on ni.com i also didn´t find anything.
Kind Regards
(3,059 Views)
I think the only way is a DMX-512 to RS-232 converter and then use the standard VISA API. Please see here
http://forums.ni.com/ni/board/message?board.id=170&requireLogin=False&thread.id=111067
Hope this helps!
cheggers
Sascha
(3,042 Views)
Ok thank you,I will try it.
Kind Regards
(3,028 Views)
