AT-MIO-16-L-25 with windows 2000
What version of NI-DAQ is compatible with AT-MIO-16-L-25 and Windows 2000 for Lab VIEW 5.1?
(2,771 Views)
I think NI-DAQ 6.9.3 should do the job. You can get it from ftp://ftp.ni.com/support/daq/pc/ni-daq/6.9.3/ .
Get the files NIDAQ693.EXE and then the LV51Eng.EXE (assuming your system uses the english language). Extract both into the same directory and then run SETUP.EXE from there, selecting LABVIEW 5.1 support.
Hope this helps.
(2,771 Views)
NI-DAQ 6.1.0 is the last version of NI-DAQ to support legacy (non E-series) MIO cards. It has not been tested for newer versions of Windows.
Information on the different NI-DAQ versions
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(2,771 Views)
